hkspowers Posted September 5, 2012 Share Posted September 5, 2012 (edited) Hi all, So I have started to fiddle around with pyro 2 and I have come across this strange display problem. Everything renders fine just a viewport issue I'm having: Pyro 2 Display Error. I have tried switching between the different viewport renderers (h11, and the other gl options) and it doesn't seem to help. I do get another slight variation of this error where on every other frame the fluid appears to display a proxy version then back to full res version on the next frame. Either way renders are fine just a small inconvenience in the viewport. Any help would be appreciated, here's some info on the workstation: Nvidia Quadro 6000 Driver version 296.88 Edited September 5, 2012 by hkspowers 1 Quote Link to comment Share on other sites More sharing options...
dbukovec Posted September 5, 2012 Share Posted September 5, 2012 hi, this was fixed couple of versions back, download a daily build and it should work 1 Quote Link to comment Share on other sites More sharing options...
hkspowers Posted September 5, 2012 Author Share Posted September 5, 2012 Oh wow I guess I'm behind the times haha. Thanks man will do! Quote Link to comment Share on other sites More sharing options...
hkspowers Posted September 5, 2012 Author Share Posted September 5, 2012 (edited) SOLVED! Thanks dbukovec working great now went to 12.1 Edited September 5, 2012 by hkspowers Quote Link to comment Share on other sites More sharing options...
dbukovec Posted September 6, 2012 Share Posted September 6, 2012 cheers! Quote Link to comment Share on other sites More sharing options...
