Pyro PScale fieldforce influence?
Xsiv
Hi All,
I have been trying to get vector velocities from my geometry and apply them to a smoke pyro effect.
This scene seems to be working. I looked at the example that is provided with Houdini and they have used PScale.
I thought, well if I create smaller spheres at the bottom and larger as you go higher, I could get a gradual swirling effect.
I cannot see how to use PScale in this fashion. I just used a random distribution of size and don't know how to hook up the PScale to work.
Anyone mind taking a look-see and let me know what I am missing?
Thanks
Chris
geo_fieldforce_velTest.hipFetching info...
I figured it out.
Don't use the sopgeo node - use the sopvectorfield node into the fieldforce.
Make sure to sample via points and the default operation = set always.
The big one is to set the force attribute to the proper vector. Is the example I used it is "v".
Thanks
Chris
  On 9/6/2012 at 6:28 PM, Xsiv said:
I figured it out.
Thanks
Chris
Mind posting your scene file so we can see in more detail what you mean?
