Rename materials according to a parameter
ben
I'm trying to do something similar. When you load a geometry file with the "`" key get a geometry node automatically named for the file sop's file string. I would like this to persist, so that choosing a different file will again rename the geometry node.
I've not done any python expressions or callbacks before, so thanks in advance for the guidance.
Seriously did not know that ` was a short cut for loading a file. Thanks :)
I don't think something like that is very hard. Add the following to the callback for a file parameter in your asset.
import os; kwargs["node"].setName(os.path.basename(kwargs["node"].evalParm("file")))
Where "file" is the parameter name that should be used to set the node's name.
EDIT: Make sure you set the callback to Python.
Edited by hopbin9
