Fattak Posted September 9, 2012 Share Posted September 9, 2012 I've got a very basic and standard setup for a sphere moving through a rectangular container half filled with water. All other settings being the same, when I vary particle separation, the simulation changes significantly. It looks like the collision velocities increase with increase in resolution, as demonstrated in the images below. Velocity Type: Point Collision Type: Volume Collusion Velocities: Point Smoothing: 0 (i.e., Purely FLIP) Ignore Mass of particles: True Particle Separation: 0.2 Particle Separation: 0.1 Particle Separation: 0.05 As you can see ... the high the resolution, the more "reds" there are in the velocity field. I think this is causing the significant change in simulation results across different resolutions. Any ideas why this happens? or how I might work around it? 1 Quote Link to comment Share on other sites More sharing options...
Netvudu Posted September 9, 2012 Share Posted September 9, 2012 (edited) For the last 1231255135454543 years, every time I changed the resolution of a fluid simulation I got different results, and not just in Houdini but in every fluid dynamics software. For SPH methods this is usually pretty easy to explain: more particles = more interaction between them = different behaviour. Regarding FLIPs,even not knowing the code "inside" Houdini´s FLIP solver, if I understand it correctly, we´re talking about a solver copying the particle’s velocities onto a grid. At the grid the solver uses a non-divergent magicthingamajicwonderfulthingy method to calculate a new velocity field, and then copying this new velocity field back onto the particles. So, again it makes perfect sense to me that more particles change the actual behaviour of the simulation. Now, as for how to obtain the same results on higher resolutions, you´re basically asking for an upres method for FLIPs, which AFAIK it´s not included into Houdini...yet. If you plan to do or prototype one yourself, this might prove interesting http://zaharidichev.com/2012/02/velocity-transfer-particle-data-expansion/ Hope this helps. Edited September 9, 2012 by Netvudu Quote Link to comment Share on other sites More sharing options...
ikarus Posted September 10, 2012 Share Posted September 10, 2012 What happens when you increase smoothing proportionally to the increase in particle separation? Quote Link to comment Share on other sites More sharing options...
old school Posted September 18, 2012 Share Posted September 18, 2012 You can always run the low res simulation, cache the vel volumes to disk and then run a high res sim copying those vel fields directly in to the high res vel volumes in to the vel fields. What you get is a higher res sim but heavily influenced by the lower resolution flip sim. If you have watched Jeff Lait's recent how to build a fluid solver from scratch or have read the flip paper you will know that the smoothing control implemented on the Flip Solver DOP controls how much of the previous frame's particle velocity to mix in to the result of the vel fields after running through the Project Non-Divergent step. So in this up res flip simulation, the smoothing parameter allows you to add in more or less of the particle behaviour on top of the overridden vel field. You get the bulk of the motion from the low res flip sim along with some more of the high res detail. Just one way of many of running an up-res flip sim on a low res sim. The technique of using sampling of a high res particle field on a low res one from the link reference above is yet another and isn't very hard to set up in Houdini. Although it does look very fluidy with not too much control. It does look like high res particles driven by a low res particle sim with no added "behaviour". I like to convert things to volumes taking the hit just once (in the low res flip sim) and then sample the high res particles in to the low res volume field. Faster than constantly doing a point look-up and you have similar control. If you use masks to control where to apply the low res velocity, you can get even more control. Up to you. To get more of the high res flip behaviour mixed in, you would have to take greater care in how you composite the low res vel volumes in to the high res field. To do this, copy the vel field to say vel_low_res, copy the vel volumes from disk in to vel_low_res then use a Gas Linear Combination to mix the vel_low_res in to the vel fields. This is VFX so what looks good rules and not some super accurate fluid simulation. More ideas: Solve the initial flip sim with a huge particle separation and see how far you can push the low-res to high-res up-step and still have something that looks like a liquid fluid simulation. Try a three level up step: Very low res vel cache. Low res vel cache. High res sim influenced by the very low and low vel volumes. Calculate the boundary of the velocity on the low res sim and scatter points within that boundary, transfer the vel to those particles and then use these to influence the high res simulation. That way you can keep more of the up res bulk motion and constrain the areas that are of interest to the lower res simulation. low_res_vel_applied_to_high_res_flip.hip.zip 1 Quote Link to comment Share on other sites More sharing options...
old school Posted September 18, 2012 Share Posted September 18, 2012 (edited) Here's the base low res sim: Then the upres flip sim driven by the low res vel volumes cached to disk. Same bulk motion as the low res simulation but with reduced velocities across the board: And finally the straight flip high resolution sim identical to the up res without the influence of the low res vel fields. Considerably different behaviour than the low res sim: What's interesting is that the low res sim and the last high res sim have similar velocity values while the high res flip sim driven by the low res vel fields has on average lower velocities. Possibly in part due to the fact that there are more particles to carry the same amount of velocity per unit area means less velocity as you increase the resolution of the sim to get a similar behaviour... Btw the black regions after the sphere in the last high res straight flip sim image is due to my lazy ass placement of the velocity plane at the lower half of the sphere and not through it's middle therefore you are seeing the the velocity vectors straight down and are looking at the velocity vectors edge on. Edited September 18, 2012 by old school 3 Quote Link to comment Share on other sites More sharing options...
draxysd Posted September 20, 2012 Share Posted September 20, 2012 @old school Hi, was just wondering if you can point me in the right direction regarding the @name= syntax. It is the first time I have seen it, and although I can imagine what this command is specifically doing, I would like to know where in the help docs is this topic covered. Thanks Quote Link to comment Share on other sites More sharing options...
old school Posted September 20, 2012 Share Posted September 20, 2012 I don't know if it is documented per se... The @ ampersand is used as a prefix when you want to evaluate an attribute in the group field as all SOPs now respect this. If you had a Cd Color attribute you could work on all geometry that had red greater than 0.5 by typing: @Cd.0>0.5 with NO spaces. Many conditional operations are supported: ==, !=, >, <, >=, <= @name=vel.* in a group field that works with volume primitives would now only work on any volumes with the primitive "name" attribute set to "vel.*" which expands to vel.x, vel.y and vel.z. This group syntax is being used more often these days as it is pretty convenient. Quote Link to comment Share on other sites More sharing options...
Davvechan Posted March 5, 2024 Share Posted March 5, 2024 On 9/18/2012 at 6:57 PM, old school said: Here's the base low res sim: Then the upres flip sim driven by the low res vel volumes cached to disk. Same bulk motion as the low res simulation but with reduced velocities across the board: And finally the straight flip high resolution sim identical to the up res without the influence of the low res vel fields. Considerably different behaviour than the low res sim: What's interesting is that the low res sim and the last high res sim have similar velocity values while the high res flip sim driven by the low res vel fields has on average lower velocities. Possibly in part due to the fact that there are more particles to carry the same amount of velocity per unit area means less velocity as you increase the resolution of the sim to get a similar behaviour... Btw the black regions after the sphere in the last high res straight flip sim image is due to my lazy ass placement of the velocity plane at the lower half of the sphere and not through it's middle therefore you are seeing the the velocity vectors straight down and are looking at the velocity vectors edge on. I found this old post. Even though there is a bunch of new cool upres tools in Houdini20, its good to be aware of the old ways. If you would upres a section with this way, and want to mesh it together with the low res, how would you do it, without getting a seem on the edges? Quote Link to comment Share on other sites More sharing options...
