Stalkerx777 Posted September 9, 2012 Share Posted September 9, 2012 Hi guys. I' looking for solution how to add some functionality similar to capture sop. There is Capture Frame parameter in this sop, which allows to compute capture weights data in specified frame, while reuse this data in other frames. I'd like to add this functionality into my sop. I think it should look something like this (in pseudo code): class MySopClass { . . GU_Detail *initGDP; . . } cookMySop(....) { . . if(frame != initFrame && initGDP.isValid()) { gdp->copy(*initGDP); } else { //Compute things initGDP = gdp; } } So, basically i need to recompute gdp only in initFrame (frame 1 for example), store this gdp in initGDP, and reuse it in other frames. Of course there is no isValid() method in gdp. So i can't be sure is my gdp "isValid". Is this a right approach? Any help? Thx! Quote Link to comment Share on other sites More sharing options...
edward Posted September 10, 2012 Share Posted September 10, 2012 You need to maintain a copy. eg. GU_Detail initGDP; initGDP.merge(*gdp); Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted September 19, 2012 Author Share Posted September 19, 2012 Hi again. I'm stuck with this problem guys... Once more: I need to compute primitive attribute only in frame 1, and then, just "hold" these values, in other frames.Ok, i know, that to do that i need a copy of GU_Detail. And if i make one in frame 1, and then just do: gdp->copy(*init_gdp), i get my frame 1 geometry on all other frames, and off course it's not animated, since it's just copied from frame 1. So i thought i need to copy only attribute data somehow, from init_gdp to my current gdp. So i found this in HDK Docs: for (GA_AttributeDict::iterator it = init_gdp.getAttributes().getDict(GA_ATTRIB_PRIMITIVE).begin(GA_SCOPE_PUBLIC); !it.atEnd(); ++it) { GA_Attribute *a = it.attrib(); gdp->getAttributes().cloneAttribute(GA_ATTRIB_PRIMITIVE, "udim", *a, true); } But this code only copies "attributes definitions", i.e. i get no attrib data. Don't know why it happens. So, here is my cookMySop: And yes, this SOP is for assigning id's for Foundry Mari textures long f = context.getFrame(); fpreal now = context.getTime(); lockInputs(context); duplicateSource(0, context); if (f == INITFRAME(now)) { GA_RWAttributeRef udim_ref = gdp->addStringTuple(GA_ATTRIB_PRIMITIVE, "udim", 1); GA_RWHandleS udim_h(udim_ref.getAttribute()); GA_ROHandleV3 uv_h(gdp, GA_ATTRIB_VERTEX, "uv"); if (uv_h.isInvalid()) { cout << "Vertex UV attribute not found"; UT_ERROR_ABORT; } const GA_Primitive *prim; const GA_PrimitiveList &primList = gdp->getPrimitiveList(); unsigned short int udim = 0; char udim_str[4]; for (GA_Iterator pr_it(gdp->getPrimitiveRange()); !pr_it.atEnd(); ++pr_it) { GA_Offset prim_offset = pr_it.getOffset(); prim = primList.get(prim_offset); GA_Range vtx_range = prim->getVertexRange(); GA_Offset vtx_offset = vtx_range.begin().getOffset(); UT_Vector3 uv(uv_h.get(vtx_offset)); udim = (int)(ceil(uv[0]) + floor(uv[1])*10) + 1000; sprintf(udim_str, "%d", udim); udim_h.set(prim_offset, udim_str); } init_gdp.clear(); init_gdp.copy(*gdp); } else { for (GA_AttributeDict::iterator it = init_gdp.getAttributes().getDict(GA_ATTRIB_PRIMITIVE).begin(GA_SCOPE_PUBLIC); !it.atEnd(); ++it) { GA_Attribute *a = it.attrib(); gdp->getAttributes().cloneAttribute(GA_ATTRIB_PRIMITIVE, "udim", *a, true); } } Also, i found something interesting here:GA_AIF_Merge This seems to be a solution, but this attribute interface is pure virtual, and i have no idea how to implement it. Any help? That's it for now, thx. Quote Link to comment Share on other sites More sharing options...
edward Posted September 21, 2012 Share Posted September 21, 2012 You call getAIFMerge() to get it from your attribute ref. Quote Link to comment Share on other sites More sharing options...
