Faceted Polygonal Look
I was looking for a good way to achieve a faceted polygonal shader similar to some of the recent stuff done in C4D:
http://geoaday.tumblr.com/
http://www.behance.n...Posters/5064977
I hoping to achieve this within the shader itself: currently the only way I am getting a similar effect is via the Facet SOP (by fragmenting the mesh - using Mantra Surface Material) see below:
post-7196-0-39074100-1348724338_thumb.jp
Any help is much appreciated.
Just connect Ng instead of N whenever applicable in Vops. Sometimes it's easier to overwrite N in displacement shader (pluging Ng into N output), so that the whole surface shader sees facetednormals without manual rewiring.
hth,
skk.
btw. The way of faceting polygons in SOPs is to use VertexSOP->Cusp Normals. It just creates a vertex normal attribute without unwelding your geometry.
