SSS Problem with changing geometry
bdunaway
So I've got a heart model with the faces 'growing' over time. It has a subsurface scattering shader using the new Surface Model node.
It works great, but when the model is still in the growing phase, there are dark spots which I assume are due to the rear holes in the model affecting the subsurface calculations.
I wrote out a point cloud file from the full model, but that didn't help.
Where can I go from this point? Baking lighting / textures or something? Is that even possible with SSS?
post-3410-0-43921600-1349372221_thumb.jp
I wrote out one to file from a single frame only - the one of the full model - because I thought that might fix the artifacts, as I'm pretty sure they are caused by the SSS calculated from the incomplete model. It didn't change anything in the render though, I get the same result as when it was calculated point clouds every frame be default.
Here is a video of it if that helps:
Edited by bdunaway
