~nature~ Posted October 5, 2012 Share Posted October 5, 2012 (edited) Hi guys, Is there a way to vary the specular angle by procedural noise or texture across the surface, I am trying to modify it inside mantra surface shader without any success, it seems that houdini ignores the effect. Cheers, best regards Edited October 5, 2012 by ~nature~ Quote Link to comment Share on other sites More sharing options...
kgoossens Posted October 5, 2012 Share Posted October 5, 2012 (edited) Hi guys, Is there a way to vary the specular angle by procedural noise or texture across the surface, I am trying to modify it inside mantra surface shader without any success, it seems that houdini ignores the effect. Cheers, best regards Did you adjust the normal going into the lighting Model? Edited October 5, 2012 by kgoossens Quote Link to comment Share on other sites More sharing options...
~nature~ Posted October 5, 2012 Author Share Posted October 5, 2012 Did you adjust the normal going into the lighting Model? Nope, I only adjusted the specular normal and multiplied the parameter by some procedural noise, but it doesn't work, Do I have to adjust the normal as well? Quote Link to comment Share on other sites More sharing options...
kgoossens Posted October 5, 2012 Share Posted October 5, 2012 Attached an example. In fact you can choose between several options. bump.hipnc Quote Link to comment Share on other sites More sharing options...
~nature~ Posted October 6, 2012 Author Share Posted October 6, 2012 Thanks Kim, Probably it's a bug, I don't know, because it works well when introduce a new surface model inside the shader rather than modify the shipped one. Quote Link to comment Share on other sites More sharing options...
