cloudfx Posted October 6, 2012 Share Posted October 6, 2012 (edited) What is exactly meaning of divergence free in solver? I realized that it does not make advecting data not to be stucked in an area. How does pressure field generated and get working with gas project non-divergent node? Edited October 6, 2012 by cloudfx Quote Link to comment Share on other sites More sharing options...
Macha Posted October 6, 2012 Share Posted October 6, 2012 If it is divergence free then the fluid behaves non compressible. There is no overall expansion or constriction (hopefully and unless you specify/control it as for example in an explosion). If that wasn't the case the solutions at each step would build up unpredictable errors and your sim would go crazy. In order to do that the solver calculates how much pressure is needed to keep the sim non-divergent. It is in effect a force counter to the errors or forces that would want to make your fluid explode. That step happens in the projection. I dont know why it is called like that but I have a feeling it is related to a type of matrix that is used when solving a system if linear equations: the projection. Imagine you use normal noise as a velocity field to drive a very basic sim. In that case your sim would explode because things such as turbulent noise functions are not divergent free. If you calculate the div of such a field you will find that there is divergence. Curl noise on the other hand is free of divergence and could drive such a basic sim. In the former, more general case, you'd have to calculate the forces that would keep the field from collapsing or expanding by means of projection. Quote Link to comment Share on other sites More sharing options...
dark_cry Posted October 7, 2012 Share Posted October 7, 2012 On 10/6/2012 at 3:24 AM, Macha said: If it is divergence free then the fluid behaves non compressible. There is no overall expansion or constriction (hopefully and unless you specify/control it as for example in an explosion). If that wasn't the case the solutions at each step would build up unpredictable errors and your sim would go crazy. In order to do that the solver calculates how much pressure is needed to keep the sim non-divergent. It is in effect a force counter to the errors or forces that would want to make your fluid explode. That step happens in the projection. I dont know why it is called like that but I have a feeling it is related to a type of matrix that is used when solving a system if linear equations: the projection. Imagine you use normal noise as a velocity field to drive a very basic sim. In that case your sim would explode because things such as turbulent noise functions are not divergent free. If you calculate the div of such a field you will find that there is divergence. Curl noise on the other hand is free of divergence and could drive such a basic sim. In the former, more general case, you'd have to calculate the forces that would keep the field from collapsing or expanding by means of projection. Hey Marc, i'm interested in it too, it would be great if u just could share any simple hip for example? I'm doing some explosion RnD... Quote Link to comment Share on other sites More sharing options...
mightcouldb1 Posted October 8, 2012 Share Posted October 8, 2012 Why the projection step is called "projection" From "Fluid Simulation for Computer Graphics" by Robert Bridson: Quote If you recall from your linear algebra, a projection is a special type of linear operator such that if you apply it twice, you get the same result as applying it once. For example, a matrix P is a projection if P2 = P . It turns out that our transformation from u to u^n+1 is indeed a linear projection. Where u is the velocity at the current timestep u^n+1 is the velocity at the next timestep 1 Quote Link to comment Share on other sites More sharing options...
