kev2 Posted October 10, 2012 Share Posted October 10, 2012 This shader is beautiful in the example file but when I add it to a scene in my own files it renders without any noise? I open a basic set-up (cam, 2 area lights, Mantra), add a teapot, add the x-ray shader from the asset browser and assign. Would love to use it in a project I'm working on now but just need to be able to apply it. Thanks, Kevin Quote Link to comment Share on other sites More sharing options...
woodenduck Posted October 10, 2012 Share Posted October 10, 2012 The noise is coming from the rest sop in the example file. If you append a rest sop to the teapot and wire it in to both inputs, you will see the noise in the render. At a radius of 1 the noise will be fairly low frequency, increase the teapot radius to 8, in order to see the same as the example file. Quote Link to comment Share on other sites More sharing options...
kev2 Posted October 10, 2012 Author Share Posted October 10, 2012 Ah, thanks J! I associated rest nodes with dynamics but should have thought of that. Best, Kevin Quote Link to comment Share on other sites More sharing options...
