Houdini 12.1 Pyro2 Smoke_color Export
Hey all,
I've just been messing around with pyro in Houdini12.1 and can't seem to get the smoke_color out in anything but PBR.
Is there a reason for this?
In PBR my smoke_mask and fire_mask passes are horrible as well, which they're not in RayTrace or MicroPolygon..
Thanks
Christian
Ok to half answer my own question:
Micropolygon PBR seems to fix my mask issues...
Is there a reason though why I can't get smoke_color out of normal raytrace or micropolygon?
Tried it in 12.0 and it was the same deal.
C
Hmm...I didn't encounter that problem when doing pyro simulations. Have you tried to create a standard (not edited) mantra node, and just hit render after you create a standard fire simulation using the shelf tool? I guess it has something to do with your rendersettings or with your pyro shader.
For what I can say in general is that PBR is working great when dealing with Pyro stuff. Since they implemented raytraced shadows so nicely in combination with volumes/pyro, PBR really works well! I never used the old micropolygon rendreing+shadow-maps combo again.
ok now I get it...its about the image planes. Hm...well I used them aswell, didn't have any problems.
My settings for the planes within the mantra node: open-exr, 16 or 32bit, type vector (also for the masks, because some apps cant handle float (black/white) images), gamma 1.
Hard to tell what went wrong in your case :(
maybe try to also look at this file:
He also used the image planes.
Hope that helps!
Edited by Scratch
