To get sequence length a FileSOP ?
Again the first thing that comes to mind is a cheap solution using just 2 things:
In the File sop you can flag "Missing Frame" as "No Geometry"
and using the expression "haspointattrib" with for example the attr "P", you can know if it has geometry loaded yes or no. And maybe do this within a solver sop?
interested what the final solution would be.
I think arg expression can be useful in this case. If you follow a typical patter for naming the file , for example
$HIP/name_10_50 .$F.bgeo
then arg(chs("../file2/file"),1) should give you 10 and arg(chs("../file2/file"),2 ) should give you 50
Where file2 is the node you are using to read the written files. Write these expressions in inrange1 and inrange2 para of time warp sop. Refer attached image.
post-4903-0-19989300-1350463137_thumb.jp
Edited by sadhu
Check this detailed list of global expression variables. I'm sure there is one that suites your needs:
http://www.sidefx.co...houdini12.1/expressions/_globals
EDIT: For some reason the link is interpreted wrong here, so please just copy paste it into your browser. It will work then.
I'd suggest $RFSTART and $RFEND or just $FSTART and $FEND
Hope that helps! :)
Edited by Scratch
import os
path = "C:\\TEMP\\"
splitCharacter = "_"
list = []
for filename in os.listdir(path) :
basename, extension = filename.split('.')
prefix, value1, value2, number = basename.split('_')
list.append(number)
highestnumber = max(int(i) for i in list)
lowestnumber = min(int(i) for i in list)
return highestnumber[/CODE]
change your timewarp node from hscript to python and paste the code.
just change it to return lowestnumber for the min range.
It should work with you naming convention : prefix_value1_value2_number.bgeo
Edit: it assume there's only one sequence in your path.
Edited by ben
Thanks ALL really good idea.
These days I am charge of game effect design for fx concept of previz.
I have been used Houdini that is my lovely tool.
In Game Effect, Houdini is powerful and fast.
According to your advice, I will try to define file naming.
When finishing, I will upload with other questions.
Talk to you continuously.
