When making a particle, What is practically a difference between Scene
Hi,
I suddenly have a question.
When making a particle in Houdini, It can see at Scene View and Particle View Panels.
But I do not actually know. Which those are difference?
Essentially I want to know why Houdini support a couple of panels.
Please kindly let me know.
Best
Jamie Jung.
Edited by jungjaehwa
The Particle View pane is needed if you're using the old-style stand-alone particle context under /pop, as opposed to the default set up that the particle shelf tools give you under SOPs (Geometry). If you're using the default set ups, Scene View should be fine.
