R_cyph Posted November 5, 2012 Share Posted November 5, 2012 Hey all, I'm trying to apply a volume blob to each particle in my sim. I'm already controlling the size of each particle blob at render time with pscale and age attributes etc. but for some reason I can't seem to control per particle density with the same attributes. I'm using a simple volume cloud shader i got from the waterfall flip rendering tutorla on the sidefx website. Please help! Quote Link to comment Share on other sites More sharing options...
ikarus Posted November 6, 2012 Share Posted November 6, 2012 If you're using vm_uniformvolume to render your points, then you wont be able to vary the density per point since its converting your geometry to a uniform volume, afaik. You should look into making a CVEX shader to generate a volume at render time, where you can use any arbitrary attributes you need to vary your field. Quote Link to comment Share on other sites More sharing options...
R_cyph Posted November 7, 2012 Author Share Posted November 7, 2012 (edited) I just want a little volume cloud shader with per particle density. isn't there some shader that does this that doesn't create a uniform volume? EDIT - removed the properties node from my shader which contained the "uniform shading property" and I can now adjust density per particle I also have another question: I have a cached out particle sim that I'm using to test my volume shader. When I use the cached to disk particle sim the volume shader just grabs the pscale and creates a spherical volume blob for me. If I try and apply the volume shader to a set points I created from a scatter sop then it doesn't work. I have to copy stamp a sphere to each point or a metaball . I notice the particle system has the same number of vertices as points. But, my scattered points just shows 0 vertices. My question is how can I convert my points to vertices so I can skip the "copy sop" step. Thanks Edited November 7, 2012 by R_cyph Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted November 7, 2012 Share Posted November 7, 2012 My question is how can I convert my points to vertices so I can skip the "copy sop" step. add sop -> particles tab -> add a particle system ? Quote Link to comment Share on other sites More sharing options...
