Custom Panels
Hi all!
I'm trying to create my own custom panel at the moment, but I don't know how to access data from my own panel. For instance, I have a button and a text field. As a test, I would like to have the button display a message box showing the value inside the text field. However, I don't know how to access the value inside the text field. Any ideas on how to get it?
Thanks,
fixxorion
Use $V. For example, in the script for your input field, use "message $V".
So in order to have a button query the value of a checkbox.....
Have the checkbox set an env. variable. setenv myCheckBox = $V
Then in the button you would have
message $myCheckBox
Is this the right direction?
Better yet....I'll buy you a Coke if you can get the cuquery() expression to work.
jim.
hm...I seem to have figured it out. In the inputfield's command I put the following:
cuset -p panel1 -n myInputField.val -v $V
And in the button's command I put:
message `cuquery(panel1, myInputField.val)`
It seems strange that I would need to update the value, but it wouldn't work otherwise. Hope this helps someone else out!
Later,
fixxorion
