mikeo Posted November 8, 2012 Share Posted November 8, 2012 When i try to access dop object particle Data from within a popsolver i just get zeros. I have tried using both $DENSITY and hou.lvar('DENSITY') with same result. Do i need to explicitly import dop object data into the sop solver? Currently i am just importing the points with a NULL called 'source1'. Which matches the new particle generator in the New Particles tab. I suspect i am missing a fundamental of dops data here..... attached is the simple hip Thanks Quote Link to comment Share on other sites More sharing options...
mikeo Posted November 9, 2012 Author Share Posted November 9, 2012 So after futher investigation.... I was trying to read 'density' using the local variable mapping(which does not exist) so using the expression function 'poppoint' works. Rookie error. Quote Link to comment Share on other sites More sharing options...
