Project curve onto sphere with fixed curve length
Dear all,
I am trying to project a curve onto the surface of a sphere.
Please see the attached file.
The requirement is to keep the distance between points the same.
In this case, the ray sop can not do what I want.
So I try to write a python node to project point on to surface in order.
The algorithm is like this:
1.create a circle for each point on curve
2.get the intersection curve between circle and sphere
3.find a point in intersection curve with distance close to the length between this point and previous point
4.move the following point according this new position
5.do 1-4 one by one
Because getting the intersection curve is difficult for me, so I try to make a sub sop network to do this.
I want to get intersection curve by cooking the OUT node in sop network.
The problem is I always get nothing in that node?
Is there a better way to get the result I want without using sop network?
problem.hip
test.otl
