Simple Smoke Sim from Scratch
Annon
Just having a play around in DOPs. I've been using a lot of GAS nodes recently so thought I'd start building up a smoke sim from scratch, just to further my understanding of it. But I hit amateur hour and can't get out of it!
I just wanted to add density and temperature, add bouyancy to velocity from temp and advect density by it.
For some reason temperature advects, although it disappears outside of the density bound. And density doesn't advect at all.
What am I missing here?
Christian
basicSmokeSim.hip
Christian
you're missing the most important step in the fluid solve, projection.
fluid solve = advection + forces + projection/incompressibility
add a gas project node and your fluid works fine
