cloudfx Posted November 20, 2012 Share Posted November 20, 2012 "gas linear combination with openCL" VS "gas calculate" Base on the expectation of gas linear combination's field + field(add) and gas calculate's field + field(add) does same calculation, only gas linear combination has openCL option, does that mean only gas linear combination can use gpu when they calculate same thing? Quote Link to comment Share on other sites More sharing options...
Solitude Posted November 20, 2012 Share Posted November 20, 2012 Yes, that is what that means. Gas linear combination was introduced in h12, and is from what I understand faster anyway, and therefore should be used when possible. Quote Link to comment Share on other sites More sharing options...
