rich_lord Posted November 25, 2012 Share Posted November 25, 2012 Im having alot of trouble with the clip SOP. When I apply it within a for each sop, it isn't properly splitting up the primitives. Huge primitives get created, rather than lots of small ones. I made a hip file to demonstrate the problem. It uses the clip SOP to split a grid into pieces inside a foreach. Then it puts one primitive inside a group per frame, so you can move the timeline forward and see the shape of the primitives it generates. I see in a peter Quint tutorial that this technique works for him, but I cant see any difference in how he is implementing it and how I am. Any ideas? Thanks! clip_sop.hipnc Quote Link to comment Share on other sites More sharing options...
bloomendale Posted November 25, 2012 Share Posted November 25, 2012 You're cutting initial grid every time and merge it. But you need to cut geo from last loop. I changed each sop (actually added mine) so that every new turn clip SOP gets geo from last iteration. 3ak_clip_sop.hipnc Quote Link to comment Share on other sites More sharing options...
rich_lord Posted November 25, 2012 Author Share Posted November 25, 2012 Thats great bloomendale - really helps me understand the foreach. I was misunderstanding the feedback and the Merge Results flag on the foreach node. Thank you! Quote Link to comment Share on other sites More sharing options...
sadhu Posted November 26, 2012 Share Posted November 26, 2012 Im having alot of trouble with the clip SOP. When I apply it within a for each sop, it isn't properly splitting up the primitives. Huge primitives get created, rather than lots of small ones. I made a hip file to demonstrate the problem. It uses the clip SOP to split a grid into pieces inside a foreach. Then it puts one primitive inside a group per frame, so you can move the timeline forward and see the shape of the primitives it generates. I see in a peter Quint tutorial that this technique works for him, but I cant see any difference in how he is implementing it and how I am. Any ideas? Thanks! Just turn off the merge results option on foreach sop Quote Link to comment Share on other sites More sharing options...
rich_lord Posted November 26, 2012 Author Share Posted November 26, 2012 Thanks Sadhu - I noticed that the feedback checkbox was connected to this via an expression. Got it working now. The ForEach is a bit of a tricky fellow. Quote Link to comment Share on other sites More sharing options...
