magneto Posted December 5, 2012 Share Posted December 5, 2012 Hi, Is there a way to reverse the Carve SOP's starting position without changing the Carve U values? I want to carve a curve from 0 to 0.2 in U, and I thought the Carve's start position is dictated by the point numbers, where point 0 is the starting U = 0. I use Sort -> Reverse before the Carve but the result is still the same. How does Carve know where to start if it doesn't use the point numbers? I know I could get what I want by using 0.8 to 1 in U values but I want to know if this is possible to do outside the Carve and what dictates the starting U position? Thanks Quote Link to comment Share on other sites More sharing options...
DanBode Posted December 5, 2012 Share Posted December 5, 2012 Reverse sop! 2 Quote Link to comment Share on other sites More sharing options...
magneto Posted December 5, 2012 Author Share Posted December 5, 2012 Thanks Dan, it works great Quote Link to comment Share on other sites More sharing options...
