difference between hres and low res mesh based on uvs in vops
jumper
I have an animated high res poly mesh with uv's and a low res poly mesh with uv's. I was wondering if there is a vop solution for getting the difference of the two meshes based on the uv coordinates and putting that into the colour of the high res mesh.
I have attached a hip file.
Thanks
Stephen
difference.hip
