Change Point List
BOON
If you use a Sort SOP after your geometry and select Shift under the point tab, and make the offset 1, it will shift all your points up 1 number. However, I believe it works in a loop, so it then makes your last point 0, instead of adding a number up.
Not sure if there is a way to just add more.
Edited by Eucalyptus
One more question regarding pointlist...
is there anyway I can return the first 10 numbers from a pointlist that gives me 20 point numbers?
I was thinking using "arg", but how do I tell it to return more than just 1 argument?
