Is there a way to query the current context in Python?
magneto
I want to know if the current context in the network editor is SOP, or VEX, or DOPs, etc. I could get the type from hou.selectedNodes, but a selection has to exist and this seems a little indirect.
Is this the only way, or is there some other way to get the current context in Houdini?
You can get it by asking the pane tab for it's current location, then getting the child type category for that.
For example, panetab15 is a network editor tab at /obj.
>>> hou.ui.findPaneTab('panetab15')
<hou.NetworkEditor panetab15>
>>>hou.ui.findPaneTab('panetab15').pwd()
<hou.Node at /obj>
>>> hou.ui.findPaneTab('panetab15').pwd().childTypeCategory()
<hou.NodeTypeCategory for Object>
# Now inside a geo object (/obj/geo1)
<hou.ObjNode of type geo at /obj/geo1>
<hou.NodeTypeCategory for Sop>
  • Like 2
Hi Graham, I looked at the pane.selectPosition and it returns a position like you said, after you click somewhere in the network editor. Would there be a way to force or cancel this mode so I don't have to click? Because otherwise it attaches the node to my pointer, but I just want to passively query the position. That's why I thought maybe there is a way to force dropping the node to get the current position.
I will keep digging. Thanks again :)
I found out that it's possible by using ctypes which is what I ended up doing for people who want to know :)
Edited by magneto
  • 2 years later...
Hey Ryan, are you able to share an example of how you did this? Thanks!
Hey man, I stopped using ctypes long ago and now do it this way:
pane = kwargs['pane']
contextname = pane.pwd().childTypeCategory().name()
