leo3d Posted February 4, 2004 Share Posted February 4, 2004 I want make trail effect like the under image,can anyone help me Quote Link to comment Share on other sites More sharing options...
Stremik Posted February 4, 2004 Share Posted February 4, 2004 The movement of cube, is it going to be an RBD or a path animation? As for the trails, I think in both cases your best choice is a Carve SOP. Quote Link to comment Share on other sites More sharing options...
anakin78z Posted February 4, 2004 Share Posted February 4, 2004 err... well I think the picture description tells you how to do it. animate a box, append a trail sop, set your trail length as high as you want, set result type to Connect as Mesh, and set Connectivity to Columns. That's all there's to it. Quote Link to comment Share on other sites More sharing options...
leo3d Posted February 5, 2004 Author Share Posted February 5, 2004 hi anakin78z , thanks for you help i know you say .and i already do it when i post the topic , but i don't konw how to separate the mesh(creat by trail op)(such as a box has eight vertex and trail op creat looks eight curves,but in fact it is one mesh,i want separate and convert it to nurbs curve ) Quote Link to comment Share on other sites More sharing options...
leo3d Posted February 5, 2004 Author Share Posted February 5, 2004 hi Stremik:)thanks for you help i can use use a carve op separate curve ,thanks again Quote Link to comment Share on other sites More sharing options...
