Stremik Posted February 5, 2004 Share Posted February 5, 2004 This is just a small tip on how to customize a bit Houdini help browser. For those who doesn't know it allready. If you have some resources on the web or on your harddrive that you use on the regular basis and want to access them from embedded browser but don't want to type in a path by hand every time, you could just edit HelpPaneLinks file which is located in HFS/houdini/config. Just add your links in that file and next time you start Houdini you will find them under "Go" menu item in help browser. It's a preatty cool replacement of a "Favorites" that you can find in any other web browser!!! Vladimir Quote Link to comment Share on other sites More sharing options...
