UV offset HOT for maya
teeejer
Has anyone had any luck animating a UV offset on the HOT shader. I've tried using at top down projection and it worked rendering frame by frame but the projection seems to be overridden in a batch render.
I assume there is already some sort of projection happening behind the scenes. Does anyone know a work around for this?
The effect I'm looking to create is ocean rushing past a stationary object. Any help would be greatly appreciated.
Thanks!
-TJ
