yongbin Posted January 31, 2013 Share Posted January 31, 2013 I tried "houdini newfile.hip" but had no luck. Is there a way to make a new hip file directly from command line? I am using windows. Thank you! Quote Link to comment Share on other sites More sharing options...
pyrochlore Posted January 31, 2013 Share Posted January 31, 2013 Use hython interactive interface. It starts an empty hip file for you when you get in. Use hou.hipFile.clear() to clear everything. then use hou.hipFile.save(fileName) to save your file. you can also write the command you just typed into a python script. then run it from command line. Quote Link to comment Share on other sites More sharing options...
yongbin Posted January 31, 2013 Author Share Posted January 31, 2013 Yes! Thank you, that's what I want~ pyrochlore! and one more.. Is there any difference use hou.hipFile.clear() or not? Thank you for helping me! Quote Link to comment Share on other sites More sharing options...
pyrochlore Posted January 31, 2013 Share Posted January 31, 2013 If you just start a new session, no need to use hou.hipFile.clear(). Quote Link to comment Share on other sites More sharing options...
yongbin Posted January 31, 2013 Author Share Posted January 31, 2013 Again, thank you for your help, pyrochlore! Quote Link to comment Share on other sites More sharing options...
