jungjaehwa Posted January 31, 2013 Share Posted January 31, 2013 Hi Everyone, I would like to ask you about a Vopsop Sop. As you can see attached file, I made spheres rotating each X-axis. But I want to control a Vopsop Sop instead of Copy Sop. So I have tested in vopsop with Transform Matrix vop, but fail. How to do in Vopsop Sop append a vopsop after copy sop? Please let me know. geo_rotate.hipnc Quote Link to comment Share on other sites More sharing options...
bloomendale Posted January 31, 2013 Share Posted January 31, 2013 You still need copySOP to make 5 additional copies. I used 2 vopsops - one to orient and place each box to template point (you can make it with copySOP using second input) and second - to rotate along arbitrary axis (used local X of template point) 3ak_geo_rotate.hipnc Quote Link to comment Share on other sites More sharing options...
jungjaehwa Posted January 31, 2013 Author Share Posted January 31, 2013 (edited) Hi Bloomendale, Thanks for sharing precious your time. I am glad to hear from you so soon. I am looking at your attached file, but I can't understand fully at once. Specially There are first sight about Quaternion and QuaternionToMatrix3 VOP. To understand your file, I have to study math for more. It is difficult node in vopsop.^^ -----------------------------pass time for 3hours ------------------------------------ I guess you solve this problem with P, N, up, cross, and Quaternion mainly. To explore your hip file, I am happy. Have a great day. If you possible, I would like to heard what your logic.^__^ Edited January 31, 2013 by jungjaehwa Quote Link to comment Share on other sites More sharing options...
gui Posted January 31, 2013 Share Posted January 31, 2013 See the files... I´m not an quaternion expert, but I my setup is somewhat similar, since the idea in the transform matrix is the same, using vector-3 or quaternion... geo_rotate.hipnc 3 Quote Link to comment Share on other sites More sharing options...
jungjaehwa Posted February 1, 2013 Author Share Posted February 1, 2013 (edited) Hi Guilherme, That's pretty good. Really really Thanks you. This is just what I meant. Your handwriting explanation help so much for me. It is a solution to make rot axis! OK, I am able to understand. Thank again. Jamie Edited February 1, 2013 by jungjaehwa Quote Link to comment Share on other sites More sharing options...
gui Posted February 1, 2013 Share Posted February 1, 2013 I´m glad I could help! If you want to mimic bloomendale´s setup, instead of using the vector pointing up (0, 1, 0), use a facet sop computing normals and use it in the vop sop (in another input). Quote Link to comment Share on other sites More sharing options...
jungjaehwa Posted February 5, 2013 Author Share Posted February 5, 2013 Thanks a lot. You already look like know what I will make.^^ Have a great day. Quote Link to comment Share on other sites More sharing options...
