Pyton Optimization
kni8_2k
Hi All,
I was just writing a bit of python code that goes through an object and creates a dictionary of attributes and vertex indices.
It works fine for small meshes(under 100k Points, but as you get bigger it inevitably gets slower. I've tracked the majority of the slowness to a couple of lines that is run many times (per vertex)
attribStack[name].append(v.point().attribValue(attr))
indexStack[name].append(v.point().number())
I think this is because of how HOM is accessing the info (or better, how I am accessing the info through HOM)
here is the code block :
attribStack = {}
indexStack = {}
for attr in myGeo.pointAttribs():
if attr is not None:
name = attr.name()
attribStack[name] = []
indexStack[name] = []
attribStack[name].append(str(attr.dataType())+str(attr.size()))
indexStack[name].append(str(attr.dataType())+str(attr.size()))
for prim in myGeo.iterPrims():
for vid in xrange(prim.numVertices()):
# get vertex
v = prim.vertex(vid)
indexStack[name].append(v.point().number())[/CODE]
The basic things that I need to happen are :
Create a list of values for each attrib
Create a point index on the vertices (for shared data)
Any thoughts on other ways to optimize this bit of code. perhaps I'm missing the obvious answer.
Edited by kni8_2k
I was recomended to use pointFloatAttribValues by sYmek on the sidefx forum.
Here is a quick implementation.
But I still have the same problem when I am going through vert attributes. (like UVs)
[code]
attribStack = {}
indexStack = {}
vList= []
startb = time.clock()
name = attr.name()
if str(attr.dataType()) == "attribData.Float":
listPAttrib = myGeo.pointFloatAttribValues(attr.name())
pAttribSize = attr.size()
vindx = 0
for v in vertIndex:
for indx in range(pAttribSize):
attribStack[attr.name()].append(listPAttrib[(v*pAttribSize)+indx])
indexStack[attr.name()].append(vertIndex)
print (time.clock()-startb)
[/CODE]
Edited by kni8_2k
