O.Heid Posted February 4, 2013 Share Posted February 4, 2013 Hi together, I try to save a own build shelf in my $HIP Folder: Problems with modifying 'lsr:' it or its file may be read-only, or the default shelf file may be inaccessible.Cannot change the file to....blabla.shelf I have write access, I already tried to copy the default.shelf into this folder (I'm sure that this is the wrong way) - still the same error. Any suggestions? Thank you in advance Cheers Quote Link to comment Share on other sites More sharing options...
