motionprojects Posted February 17, 2013 Share Posted February 17, 2013 (edited) I have two sources, first is an animated mesh, constant topology, let's say it comes to us in a cache. Second source is single mesh, a modified deformation of the first source at frame 1. How could we apply that deformation across all frames of the animated cache? As a real world example, imagine the first cache is an animated human face talking and emoting, etc. The second source, is frame 1 of the human. In a sculpting program they have altered the ears, nose, expression, etc retaining topology. But this mesh looks like a Orc or something. I've looked at blendshapes, ray sop, but it seems that I want to blend in pure point position + projections along normal + transform matrix to make the deformation follow the cache. Is there some obvious solution I'm missing, or is this some vopsop magic I require? In some workflows, people would use a displacement map if the faces were similar, but I'm looking for something more generalized and suited to more radical shape changes. I'm attaching a hypothetical example using a torus in this file. Thanks for any help. Edited February 17, 2013 by motionprojects Quote Link to comment Share on other sites More sharing options...
sanostol Posted February 17, 2013 Share Posted February 17, 2013 (edited) You can use the hscript command sopcreateedit to get a editSOP that contains the necessary edits to get to You reshaped model. next You need a reference shape in the second edit input so houdini knows how to apply the shape during animation have a look at the example If You can store a orient (quaternion) attribute on You cache, tracking the orientation during deformation houdini can also apply deformation right (option -o) cd /obj/pretend_torus_anim_is_cachedsopcreateedit edit1 deforming_torus reshapedsopcreateedit -o edit2 deforming_torus reshaped[/CODE]blend.hipnc Edited February 17, 2013 by sanostol Quote Link to comment Share on other sites More sharing options...
motionprojects Posted February 17, 2013 Author Share Posted February 17, 2013 Yes indeed, this works great. Tried it on my own to see if I could build it from scratch. Trouble at first with my orient attribute remaining at 0,0,0,0 after the sopcreateedit -o I had missed that there needed to be a 1 in the 4th float of the orient value to start it off. Thanks for the assistance! Quote Link to comment Share on other sites More sharing options...
