Point movement on geometry
Andzelmas
Hello,
Asked this in the sidefx forums, but no reply so far. Decided to post here too.
I have no idea how to best approach this: i need points to randomly move around on a surface.
Played around with creep, but i'd like some more control or maybe i'm using it incorrectly?
I tried some ideas i would use in softimage Ice, but so far nothing worked...
My goal is to later make lines out of the points and the lines into sort of "veiny" structures/tubes.
Any advice?
you could try using scatter.
if you afterwards select a number of points out of the generated points,
and let the points move towards random nearby points and repeat this over and over,
you can get some movement I guess.
I am not entirely sure what you use and what you need, though...
if you have a flat surface that you move along, it would probably better to use something like CHOPS.
like almost everything with Houdini, there multiple ways to do this.
