Vex SOP
(I am new to Houdini.Please bear with my lack of technical knowledge of Houdini)
How does the velocity attribute work in vex?
I mean for testing it, i created a new SOP type in vex.
In the vex code i wrote the following
sop
sop1()
v={1,1,1};
After compiling it succesfully,i saved the otl file.
Then i dropped this sop in the network view and connected a line to its input and activated the sop.
The line is still at rest.
Nothing happens.What did i assign the velocity to? Where is the action?
Well you've given it a velocity attribute, but that doesn't mean it's going to move along the velocity path.
You need to stick it in a solver to do that...
You could test it with a sop solver (think it's just called "solver" in SOPs now) and add the velocity to the position every frame...
