Particle Slide on Collision
jonnyw
Hi all,
Here's a simple question about the particle slide on collision.
post-8962-0-04355700-1362556544_thumb.jp
From the attached picture you can see there's a distance between the particle and the grid plane.
Since the "Source" and the "Grid Plane" are animated with the same direction, I think it's the inherit velocity caused the distance.
Is there any way to fix it up?
particleCollision.hip
