samboosa Posted March 10, 2013 Share Posted March 10, 2013 Hello! Forgive me for asking this seemingly simple question; Similar to how a lattice can deform shapes inside a cube, is it possible to deform a shape using some sort of irregular lattice? - Samboosa. Quote Link to comment Share on other sites More sharing options...
edward Posted March 11, 2013 Share Posted March 11, 2013 You can use the "points" mode in the Lattice SOP but for the best deformation probably: http://www.orbolt.com/asset/houdini_tools::PGMVC_capt_deform Quote Link to comment Share on other sites More sharing options...
pclaes Posted March 21, 2013 Share Posted March 21, 2013 you might also want to look at the sops for deforming cloth: clothcapture and clothdeform. Also the wrapper otl that is part of this lesson is very useful - it is better than the default lattice since it can cope with rotations too. http://www.sidefx.com/index.php?option=com_content&task=view&id=1540&Itemid=344 The radii are based on metaballs, so perhaps not as good as MVC - as that I think there the weights are based on the distance to the primitives of the lower resolution cage. -- Last time I tested this, this works well, but can get slow when your low resolution cage is not so low resolution . 1 Quote Link to comment Share on other sites More sharing options...
