$F_Frame in filename string
Hello
I'm pretty new to Houdini so apologies if this is a really dumb question...
I'm trying to read in a series of 3D scans in ply format exported from another soft. They're named:
0_Frame 0.ply
1_Frame 1.ply etc...
When I put "$F_Frame $F.ply" [without the inverted commas] in the filename field of a File SOP the string appears to evaluate to " 1.ply" [ie with a space before the frame number]. If I instead put "$F Frame $F.ply" it evaluates to "1 Frame 1.ply".
Can someone tell me what I need to put in here or if I should just batch rename all the files?
Thanks very much in advance
Put curly braces around {$F} to qualify it:
${F}_Frame ${F}.ply <<< Fixed the error where I mistakenly put {} around $F
There are some that argue for . separators between frames and names and others that use _ then some use - but spaces? Windows I guess.
As far as I am concerned, I don't care as I qualify my variables with {} so the houdini string parser can properly deal with variables then write modern wrapper scripts that can deal with _, -, or . .
Edited by old school
Hi
Thanks very much for that.
Yes, I've no idea who thought that putting a space in would be a good idea but yes it's windows. The other software is Artec Studio which is a 3D scanning application [works with Artec hardware]
I tried the curly braces and it's evaluating the frame numbers now but it keeps in the braces so now it's evaluating as {1}_Frame {1}.ply and consequently still doesn't work.
Is there some way I can add this to a null for example as a string variable, evaluate it there then reference it with chs() maybe?
Thanks again for your time
I've figured out a way of doing this but it doesn't seem a very elegant method. This is what I now have in my filename field:
`strcat("G:/dumbThings/Minotaur/scansExport/front and right/",strcat($F,strcat("_Frame ",strcat($F,".ply"))))`
I'll stick with this for now and write out more sensibly named geo sequences but I'd be very interested in a cleaner solution should anyone have one...
Guest mantragora
Add your custom expresion in Edit->Aliases and Variables->Expressions:
string MyPath(string path, string filename, string extension, float frame)
string begin = strcat(path, frame);
string middle = strcat(filename, frame);
string merged = strcat(begin, strcat(middle, extension));
return merged;
and then in path
`MyPath("$HIP/Desktop/New folder/", "_Frame ", ".ply", $F - 1)`
OR
string MyFileName(string filename, string extension, float frame)
string begin = strcat(frame, filename);
string end = strcat(begin, frame);
string merged = strcat(end, extension);
return merged;
and then in path
$HIP/Desktop/New folder/`MyFileName("_Frame ", ".ply", $F - 1)`
Edited by mantragora
