Passing Python string to hou.hscript....?
CiaranM
is it possible to pass a python string as one of the arguments to an hscript command called through hou.hscript?
I'm calling the hscript command fbximport, which AFAIK has no Python equivalent. So how can I get the path argument from the rest of my code into the hscript command?
Thanks.
  • 2 weeks later...
Im trying to batch import a lot of fbx files.
Could you elaborate on how you pass the path argument to the hscript command.
So far I think it's the only thing I'm missing ...
import os
directory = "//xxxxxxx/fbx/"
listFiles = os.listdir(directory)
for fbx in listFiles :
fbxFullPath = directory+fbx
print fbxFullPath
hou.hscript("fbximport fbxFullPath")
[/CODE]
thx for you help
Edited by ben
ok, get it ! Big string as you said...
for the record :
import os
print fbxFullPath
command = "fbximport "+fbxFullPath
hou.hscript(command)
Edited by ben
