Python - getting current parm in expression
TomRaynor
I would love to know if I am using a python expression in a node's parameter.... is there a way using python to grab the name of the parameter currently being populated by the expression that you are writing?
(similar to how you can use kwargs['parm'] in an otl.
See attached scene where I have added a few more notes to try and explain this.
Thanks,
Tom
test.hip
Thanks Graham, you've saved the day once again! That works a treat. It has brought up another little python issue which I don't quite understand.
I am trying to reference a primitive attribute on my geometry via a local variable using python. It works in the hscript case but when I replicate it in python it doesn't seem to work.
I was wondering if you could take a look at the "hip" and see if I am doing something silly?
I realize that I haven't included the texture files so it will be hard to check if it is working, but they are quite big so I'd rather not upload them.
Cheers!
udimNotWorking_v01.hip
