fractured object, partition sop needs attribute create to work
Nibbler
hi, can anybody check this hip and say why it's work this way,
grid
sort(from 0 point)
facet(unique points)
attribcreate(primitive 'primitive_number' value=$PR)
partition(NR_$PRIMITIVE_NUMBER)
when I use in partition $PR all primitives act like separated primitives, but when I use primitive_number it works
doesn't make sense IMO coz: $PR == $PRIMITIVE_NUMBER
please explain
crack_ground_c.hipncFetching info...
because $PR is always updating. it's just reflects order in which primitives are worked on.
While primitive_number attrib is the copy of the $PR at that particular place in network. Then you add extrude to every primitive so you primitive_number attrib was inherited by new primitives from the one they extruded from while $PR is just recalculated to account for all (old and new) primitives.
Example:
you have 1 primitive with $PR ==0 and primitive_number == $PR (at this particular node in network) ==0
then you extrude you primitive. and now you have 5 primitives with newly calculated $PR from 0 to 4 and they all have primitive_number ==0 (inherited)
