animknight Posted April 17, 2013 Share Posted April 17, 2013 Hey guys! I have been doing some testing on alembic delayed load primitives. I exported a sphere with two groups which has different material assignments for each group using the ROP Alembic output node. I imported them back in houdini and SOHO binds the materials perfectly. The material assignments for the groups work with delayed load primitives. But when I open the alembic archive and add this attribute manually and save it as a different file with all the objects and properties copied from the original file. The material assignments for the groups work only when I load the Houdini geometry. It doesn't work with alembic delayed load primitives. What am I doing wrong ? How exactly SOHO binds the materials ? I compared both abc files but I couldn't find any changes. I have attached the files for reference. Any help much appreciated. Thanks -J AlembicTest.tar.gz Quote Link to comment Share on other sites More sharing options...
animknight Posted April 18, 2013 Author Share Posted April 18, 2013 Any ideas ?? How does alembic delayed load primitives differentiates material assignments for the groups ? Quote Link to comment Share on other sites More sharing options...
