Alexpdennis Posted April 22, 2013 Share Posted April 22, 2013 Hello! im trying to follow this digital tutors tutorial regarding voronoi fracturing and dynamics. ive made it to the point in which the tutor is isolating a piece of geometry, to use the effect on. Now, when i dont bother trying to isolate the section of geometry, all my (limited) voronoi knowledge works fine. but it seems as tho when i introduce the delete nodes, the network in which i had set up before doesnt work. specifically, i have a point node connected to a paint node to jurisdict a density of points which will, in-terms, add to my voronoi fracture detail. however, the scatter node doesnt behave the same as without the delete nodes. in the tutorial he says to add an attribute node in between the delete and the point node to get rid of ALL attributes on the primitives and the points. he puts an * in the "delete attributes" field of the attribute node. but when i do that.. it gives me an error talking about a bad attribute in that field.. im pretty sure thats the problem. and if i look at the delete node in HIS file within the "number" tab, it goes: delete by pattern and the pattern field is greyed out and has a lonesome *, and mine has a live field that says !*. im not sure if this is a version difference or what. ive tried looking for alternative/updated "all" expressions to plug in instead, but i have had no luck. any guidance for this bum would be greatly appreciated. thanks in advance to all you wonderful people:) voronoi_2.hipnc Quote Link to comment Share on other sites More sharing options...
ford77 Posted April 23, 2013 Share Posted April 23, 2013 On the "yes" part of the network you have two color attributes. One for points and another one for primitives. Delete the primitive color and the scatter will work. Quote Link to comment Share on other sites More sharing options...
Alexpdennis Posted April 23, 2013 Author Share Posted April 23, 2013 cool. thank you sir. Quote Link to comment Share on other sites More sharing options...
