substep Posted April 22, 2013 Share Posted April 22, 2013 Hi, when blowing through walls with multiple objects - outterwall, studs, and innerdrywall, What is the best way to constrain objects together? If I glue all objects together, and cluster them, they're too strong to break by an object hitting the wall, but still slowly start to fall after a few seconds. If I glue each object together to itself, then some random glue constraints to stick wall pieces to studs, that's too strong also. If I just focus on one wall, It works great, and I can achieve whatever sort of look i'm after, But things become unbreakable with multiple layers? So how are other people approaching this? what is best way to blow through a wall with more complicated objects than just concrete? Also, If I set mass manually in RBD fracture object dop, is that setting it for each piece? or for the object, then figuring out mass of each piece? thanks!! Quote Link to comment Share on other sites More sharing options...
substep Posted April 23, 2013 Author Share Posted April 23, 2013 (edited) I downloaded build 12.5.381 and it's behaving much better. I can actually get objects fully through the wall, and it seems to be respecting a high and low strength setting on glue cluster sop. nobody likes me cause I'm new Edited April 23, 2013 by substep Quote Link to comment Share on other sites More sharing options...
