DOP voronoi US's
predator
Guys (sorry for my english) iam having problem with uv's of a voronoi shatter shot , in witch iam using dynamic shatter but new faces which are created is not holding the textures . Can any one give me any solution because my dadline in very close now and i have to texture and render it
thnx
if your dynamic fracturing is not creating inside groups for the newly created pieces you must turn this option on. For that unlock the rigidbodysolver (right click- "Allow Editing of Contents"), go inside "voronoifracturesolver1" - fracture_SOP_Solver and on "voronoifracture" node- Groups tab activate Create Output Groups option.
In sop after your dopimport add an "uvproject" node, use 'inside' for Group, Group Type- 'Vertices", Projection- 'Plastic Warp' and you'll get the uv's
