ben Posted April 24, 2013 Share Posted April 24, 2013 (edited) FBX exporter support static and animated instances. ok, it's in the doc. But how exactly would you do that ? What I'm trying is to export an Instance Obj. - If I reference the object to instanciate in Instance Obj / Instance Object field, I just get one objet exported. - if I use a string attribute "Instance", a warning pop up : "Some instances could not be connected properly". so how to connect properly ? thx Edited April 25, 2013 by ben Quote Link to comment Share on other sites More sharing options...
