Calling CVEX Shader from CVEX_Context
I know a CVEX_Context can be used to load a .vex shader from disk and run it.
How can I access the .vex shader that's in a CVEX otl? This CVEX_Context will be running embedded inside a SOP, so I will be able to access the CVEX otl, and possibly get the .vex shader inside of it, and copy it to a tmp location for the shader to read, if necessary.
Detailed example of loading vex code from shops or vops is here:
http://www.sidefx.co..._c-example.html
Not sure about embedded vex code inside otl though.
Edited by SYmek
