Making a selection Gui
I saw this link today:
http://www.animschoolblog.com/2013/04/animschool-picker-released.html
and wondered how I might add something like this to my DA character. I've already got control nulls in place for the various bones and IK controllers. And I've got these exporting the relevant params to the DA, so when you select one of the controllers you get the appropriate handle, and so forth.
I started experimenting with a an object (the gui element) that when selected performs a selection script and selects another object (the controller null). I can get this to work, but what happens is that it selects the right node, but then it moves you into the DA, as opposed to staying put and just displaying the translator handle. So there's something I'm not understanding here, but I'm not sure what all is going on.
Here's a simple example of what I'm talking about:
Here's hte scene
post-4235-0-34054900-1367962609_thumb.jp
I want to select the shape in the "gui"
post-4235-0-61747000-1367962625_thumb.jp
and have that immediately select the correct controller in the rig
post-4235-0-06853400-1367962635_thumb.jp
which I can then manipulate and rotate (or translate or whatever)
post-4235-0-89829700-1367962642_thumb.jp
And have this all wrapped up in the DA. Then to view the GUI, I figured that you could open up another floating pane, set it to a Scene View, and an ortho view that's centered on the GUI shapes. Does that make any sense?
anim-gui.hipnc
myanimobj.otl
  • 4 weeks later...
Edward, thanks for the suggestion, I had a chance to get back to this, this time just using plain old buttons in the Parameter intereface. I can select an object by using
ctrl = hou.node(.....)
ctrl.setSelected()
but it always takes you into the asset, regardless of whether show_asset_if_selected is true or false. Is there an alternate way of selecting the ctrls without being taken into the DA? It does this even if the asset is locked.
