jim c Posted May 4, 2013 Share Posted May 4, 2013 (edited) I was fooling around with the BlendShape Chop and after adding some keyframes to an object in the scene, suddenly it (the blendshape Chop) starts to spit this out: "Source and Target input channels must have the same length" Any idea what I've screwed up? I'm stumped for now. walktest.hipnc Edited May 4, 2013 by jim c Quote Link to comment Share on other sites More sharing options...
anim Posted May 10, 2013 Share Posted May 10, 2013 it pretty much tells you what's wrong you need to have the same number of samples in Source and Target channels since they represent example pairs that are used to fit first input values from source to target values so keep only first 5 keyframes in your source channel and it will work or add a keyframes for every target channel to match the same number as in source and set their corresponding values Quote Link to comment Share on other sites More sharing options...
