Maximum in sets (vopsop)?
I'm trying to get the maximum value of a set in vopsop. I subtracting the centroid of a grid with the pointpos and get the length of that vector to get the distance of each point from the center. How can I get the higher value of this set? I want to plug it in the source max value of the fit node.
thanks
You can use an attribute promote from point to detail using maximum as the operation.
You can't do that in VOPs (I don't think) because the current point being processed has no way to query the other points usually. You could create an array with all the distances, but it's too much work for the buck.
Cheers
Thanks guys!
So do I need 2 vopsop to get my value? or I can do the attrib promote after the vopsop node and get the info back inside vop (place before the attrib promote node) ?
