High school project
vfxjensen
Hi Jensen!
As a student myself I know how much work it is required to actually create a 3 minutes long 3D animated video which looks good at the same time as you are learning new stuff. It is always fun to create a long video and try different animation methods although I would strongly recommend to make something simpler next time. For example instead of doing that whole animation. Your project could simply be to modell, texture and render that airplane or create a rather realistic render of that room or city, or make the sphere be more dynamic. My point is just to focus on something and do it well instead of spreading the whole workload on a long clip. You will achieve better results doing so and improve your skills deeper for each project you create. Keep on the good work and try to write it in english next time if possible. Beter audience that way :)
Cheers
